taking out a gsr....with questions
ok the a/c compressor do i need to take it off the motor or just leave it bolted on and just undo the bottom mount???? need to know...
Former Moderator
Re: taking out a gsr....with questions (GSR_hatch936)
Why are you pulling the engine out?
You don't have to remove the alternator to remove the engine.
Also if the A/c works then leave the lines attached and simply unbolt the compressor from the mount on the block and zip tie it out of the way as noted above previously.
Re: taking out a gsr....with questions (Boost_V)
this is with p30's
COMPRESSION RATIO
11.59960326572453:1cr
this is with ctr pistons
COMPRESSION RATIO
12.042422511586593:1cr
seems to me that the ctr's are better but dont know!!
COMPRESSION RATIO
COMPRESSION RATIO
MelJ
13
12-10-2010 06:25 PM
keeprollingon
08-03-2008 05:27 PM
