clutch question...
clutch question...
i have a 93 civic hatch with the 1.5L (d15b7) engine. it has whatever tranny has the really long gears in it?? what would be the best clutch to get for it? i dont want to do a motor swap!!! lol, i just want to know what i should pick. it has to be done and i wouldnt mind it running alittle better or being able to abuse it a little more often. thanks for the help guys.
Re: clutch question... (MeGotRoundEye)
ohh and i wanted to get a flywheel too. is it better to get one thats really light? or will that be bad for a stock engine with no mods what so ever? thanks again.
im hench irl
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MeGotRoundEye »</TD></TR><TR><TD CLASS="quote">wow! thanks so much for the help. </TD></TR></TABLE>
Patience is key to finding answers. Try doing some research, u might find your answers quicker than others trying to research for you.
Re: clutch question... (esco562)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by esco562 »</TD></TR><TR><TD CLASS="quote">
Patience is key to finding answers. Try doing some research, u might find your answers quicker than others trying to research for you.</TD></TR></TABLE>
yeah that is true, its kind of an odd question though most people just swap that stuff out. im starting to think nobody does anything to the d15 motors. i want to be one of the few.. my out look is if it aint broke dont fix it. but its deff broken lol. i just want to replace what breaks with better stuff. thanks
You can get the Exedy OEM replacement for under $100 on eBay. Or get a Stage 1 which is $200-$300.
http://www.clutchcityonline.com has the part numbers and you could order from them if you dont trust ebay or look in the classifieds under forum sponsors.
Re: clutch question... (doood)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doood »</TD></TR><TR><TD CLASS="quote">you dont need anything more than an exedy oem replacement. flywheel weight is your preference.</TD></TR></TABLE>
what is a good weight for the flywheel? and what are the pros and cons to a heavy or light fly wheel?
the stock flywheel weighs somewhere around 14ish lbs? thats just a guess however. the benefits of running a lighter than stock flywheel are being able to rev higher faster (less centrifugal force). the drawbacks of a lightened flywheel is the chance of your car bogging in between shifts.
since there is less weight on the flywheel itself, allowing it to spin faster sooner, it also has less mass to keep itself spinning at the same speed. hence, when you shift gears, your RPMs may drop quickly, resulting in a rougher ride.
go with a fidanza 2.3 and a fidanza 8lb flywheel.
i have had the exedy stage 2 and the fidanza 3.2 and the fidanza clutch is way sweeter. although if you want it cheap then exedy off ebay is the way to go.
http://www.ultrarev.com they sell the fidanza clutches if ur interested.
Re: (space6977)
thank you guys i have no problem spending the money on something like this seeing as how it has to be fixed anyway, i think ive made up my mind. thanks again for the help. and thanks for not just telling me to swap the motor out lol.
p.s. do you think a 6 pound flywheel would make for a ruff ride? i was looking at the zex flywheel. with the exedy stage 1 clutch.
adam4lsu
03-26-2007 07:31 PM
