Passanger Door Removal
Simple, I know.. but having some problems with the middle bolt that u can see from the inside of the car when the door is fully opened. It is stripped, i try to remove it and it just keeps spinning..
How Do i get this out???
Re: (5lugSlug)
You are going to have to wedge the door hinge away from the car while tuning the bolt, this added pressure may help catch a thread, if not then start grinding or drilling the head off of the bolt.
Re: (Duane_in_Japan)
I just remembered, not sure if it is on yours or not, is there a hinge pin that can be knocked out and leave half of the hinge on the car and half on the door, or pull the hinge from the door instead of the car, this way you will have less aligning to do later.
AgentJam
02-05-2004 08:21 AM
