Swap Info
Swap Info
Hi H-T Members !
Planning swapping B18B in my EK (Civic 2000).
For the moment, I only have the engine (Base + Head + Intake + Throttle Body).
I'm making a list of what I need to complete the swap.
Can you help me to make sure I don't forget anything.
Items in italics and bold are items I currently have !
Thanks
- Engine (Base + Head + Intake + Throttle Body)
- Tranny
- Starter from Teg 94-01
- Alternator from Teg 94-01
- Headers 4-2-1
- Clutch
- Pressure Plate
- Flywheel
- Midshaft and Axles from Civic Si 99-00
- Motor mount (don't know wich one... someone as the part #)
- Ecu
- OBD2 to OBD1 conversion harness
- Distributor from B18B
- (NOT SURE) ShiftLinkage Civic Si 99-00???? (Does my shiftlinkage from my Dx is ok ?)
Does those infos are correct ? Missing any parts ?
Thanks
Thanks
- Tranny
- Headers 4-2-1
- Clutch
- Pressure Plate
- Flywheel
- Ecu
Thanks
Re: Swap Info (Zadfz)
the shift linkage from your d series cant be reused.u can use 99-00 si civic shiftlinkage or 94up integra shift linkage..looks like u got everything ready. u will need 94 up integra mounts, rear T bracket, engine harness and u need a throttle cable from 94 up LS integra and once the swap is in, the header flange to cat might need to be rewelded.
Modified by crazyguy at 8:52 AM 10/3/2007
im not sure but i think you will also need the wiring harness from the teg, but maybe im wrong . but good luck! you plan on boostin it later on?
Re: Swap Info (that_eg_hatch_guy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by that_eg_hatch_guy »</TD></TR><TR><TD CLASS="quote">you plan on boostin it later on?</TD></TR></TABLE>
Don't know yet !
Don't know yet !
you need a obd-2 alternator, dizzy, injectors. you are gonna reuse your stock civic harness and then get a conversion harness going t the ecu
aaronboy123
04-17-2009 07:16 PM
