d16z6
d16z6
Hey guys, I was driving home from work today, car started up no problem , i get home eat dinner, go out to start it half hour later nothen, lots of power, so i was like ok starter might be gone? .. So i jump started it, it started up but made a terrible noise, start bogging back firing and the check engine light was coming on and off, so i went back home and turned it off, and there it sits? Any suggestions on what it is?
Stouts 'n' Scotch
You'll still have it stored in the ECU. Check what the code was, by the symptoms, it may be possible that you jumped timing. Hard to tell over the internet though.
Re: d16z6 (`chrisb)
usually if the check engine light is on....goodbye motor!! lol but maybe just lost compression in a cylinder. possibly a bent valve....friend had a car that did somethin like that.
im hench irl
Re: d16z6 (the_lude_01)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by the_lude_01 »</TD></TR><TR><TD CLASS="quote">usually if the check engine light is on....goodbye motor!! lol..</TD></TR></TABLE>
Thats not entirely true. Go do some research before you post your he said she said bullshit on here.
Stouts 'n' Scotch
We should set up a "Worst first post" thread, this guy would be in the top 5 at least. Don't post worthless BS like this anymore.
im hench irl
Re: d16z6 (wiZCo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wiZCo »</TD></TR><TR><TD CLASS="quote">We should set up a "Worst first post" thread, this guy would be in the top 5 at least. Don't post worthless BS like this anymore.</TD></TR></TABLE>
So far he's #1.
So far he's #1.
Re: (wiZCo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wiZCo »</TD></TR><TR><TD CLASS="quote">You'll still have it stored in the ECU. Check what the code was, by the symptoms, it may be possible that you jumped timing. Hard to tell over the internet though.</TD></TR></TABLE> that could be right i just changed my water pump and the timing belt seemed like it had a lil slack , ill check this weekend if the timing isnt on..
Re: d16z6 (`chrisb)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by `chrisb »</TD></TR><TR><TD CLASS="quote">Hey guys, I was driving home from work today, car started up no problem , i get home eat dinner, go out to start it half hour later nothen, lots of power, so i was like ok starter might be gone? .. So i jump started it, it started up but made a terrible noise, start bogging back firing and the check engine light was coming on and off, so i went back home and turned it off, and there it sits? Any suggestions on what it is? </TD></TR></TABLE>
main relay???
main relay???
Stouts 'n' Scotch
Re: d16z6 (MeGotRoundEye)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MeGotRoundEye »</TD></TR><TR><TD CLASS="quote">
main relay???</TD></TR></TABLE>
Seriously. Don't just go posting info that you have no idea what the cause or fix is.
Stouts 'n' Scotch
Re: (`chrisb)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by `chrisb »</TD></TR><TR><TD CLASS="quote"> that could be right i just changed my water pump and the timing belt seemed like it had a lil slack , ill check this weekend if the timing isnt on.. </TD></TR></TABLE>
Aha! Hopefully, that's what the problem is.
