BRAKES ~!!!!!
BRAKES ~!!!!!
I Just bought a 94 civic hb and i noticed i had disk brakes in the rear is that normal? the brakes in the rear are making a lot of nosies so i need to replace them and idk know which pads to get because i have no clue what these brakes came from. How do you verify? There a number on the back of the caliper. Does that help?
Re: BRAKES ~!!!!! (luvmihatch)
Even if its not an si and someone did a rear disc swap it sould still use the same pads as the 92-95 si 94-00 integra.
Re: BRAKES ~!!!!! (instructor74)
I was told the rear was from a LS integra, Would these rotors and pads be the same for my stock brakes in the front? Im confused Does some one have a link that tells about all the brake set ups for honda and acura
Modified by jin4g63 at 2:41 PM 10/2/2007
Re: BRAKES ~!!!!! (jin4g63)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jin4g63 »</TD></TR><TR><TD CLASS="quote">So do you recommend me ordering pads for a 94-00 integra? do these pads fit the 92-95si ? im still not sure what i should do</TD></TR></TABLE>
they are all the same. keep in mind we're talking rear disc brakes here.
90-93 integra
94-01 integra (exc. itr)
92-95 civic
96-00 civic
94-97 del sol
am i missing any more?
90-93 integra
92-95 civic
96-00 civic
94-97 del sol
1 Post
If it's not an Si, and you're still not sure, pull out the pad and take it down to your local parts store. That will give you peace of mind, I'm sure, but like was said, the pads are the same.
Unceasing Measure
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jin4g63 »</TD></TR><TR><TD CLASS="quote">I was told the rear was from a LS integra, Would these rotors and pads be the same for my stock brakes in the front? Im confused Does some one have a link that tells about all the brake set ups for honda and acura</TD></TR></TABLE>
No, of course they're not the same rotors and pads as the front. They're pads and rotors from the rear of an LS Integra. When you order pads and rotors, order pads and rotors from a 1996 Integra LS and you'll be fine. Done. /thread.
nice thread edit, and we've already answered your question more than one time.
what else do you want?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jin4g63 »</TD></TR><TR><TD CLASS="quote"> Im confused Does some one have a link that tells about all the brake set ups for honda and acura</TD></TR></TABLE>
https://honda-tech.com/zerothread?id=1811368
