Would a 92-93 Integra linakge fit an eg with b16?
Been trying to look for a DC linkage, but they are hard to get around here. Was wondering if a DA linkage fit my 92 hatch with a b16. Thanks.
Re: Would a 92-93 Integra linakge fit an eg with b16? (91EF_Si)
it works, but i think the part that bolts onto the shifter is a lot smaller, so you will have to either use the da shifter or bend the holding piece wider to fit your eg shifter on there...gl...but it does fit and does work fine too!
Re: Would a 92-93 Integra linakge fit an eg with b16? (ek4_b16a)
My stock set for my b16a was bent so i swapped it out with a set of linkages out of a 96 ls. Bolted up fine with no problems.
jc2801
12-15-2006 10:30 PM
