civic fan dead, no heater.
Old 11-27-2007, 11:28 AM
lilo_goki's Avatar
Default civic fan dead, no heater.
my radiatior fan is dead. so sometimes my car over heats. also my heater is dead also. when i push on the heater lights, it doesn't come on. any idea what's wrong. could it be the relay.
Old 11-27-2007, 11:35 AM
SinsEvil666's Avatar
i had a problem when my fan was dead as well, check your fuses (in car fuse box) that fixed my problem
Old 11-27-2007, 11:36 AM
95ProjectEJ1's Avatar
Default Re: civic fan dead, no heater.
You can test your fan by getting yourself two pieces of wire that will reach the front of your car from the battery.
Unplug the fan connector located next to the fan shroud. Now take the wires and connect the "+" on the batter to the "+" on the connector. Do the same for the "-".
If the fan turns on then it works. If it doesnt you will want to grab a paper clip (or wire) and locate the thermoswitch (fan switch) located on the thermostat housing. Unplug it and jump the female portion of the connector by inserting the paper clip in each end.
If you hear a "click" and the fan comes on then your relay is good.
I believe there is a fuse in the engine bay fuse box that does control the fan/heater also.
Old 11-27-2007, 08:33 PM
lilo_goki's Avatar
thanks guys, i'll check it out and reply back.
Old 11-28-2007, 10:08 AM
C-West Civic's Avatar
Im having same issue, so if both check out ok, stuck thermostat?
Old 11-28-2007, 11:38 AM
Default Re: (C-West Civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by C-West Civic &raquo;</TD></TR><TR><TD CLASS="quote">Im having same issue, so if both check out ok, stuck thermostat?</TD></TR></TABLE>
what exactly do u mean by both checked out ok? did u make sure ur fan was engaging when the engine was at reg. temp? or did u just test the fan to see if it worked? if u havent done so, turn on car let it warm up to reg. temp, if temp keeps rising and fan does not engage, u might want to check the fuses...or did u check the fuses as well?
Old 11-28-2007, 12:17 PM
Yea, temp gauge was almost pegged and the fan didnt kick on. Checked all fuses in both compartments, all were good. Then ran the test above, checking the fan, and it came on.
Old 11-29-2007, 09:22 AM
lilo_goki's Avatar
i just checked mine and it all works just like c-west civic. no idea why the fan doesn't come on. i'm just going to install a manual switch fan on now.
Old 11-29-2007, 03:20 PM
I was at Honda today lilo_goki and I talked to a tech there. He said he would check the thermostat ( see if its sticking ) and the 2 other sensors that regulate the cooling system ( ECT sending unit and coolin fan switch ). If you wanna test em, lemme know and ill write up the procedure.
Old 12-03-2007, 02:47 PM
lilo_goki's Avatar
kewl, thanks, can u please write up the procedure then. i would reallie appreicate it even though i already install a manual switch fan.
NAS95
01-15-2018 01:51 AM
killaberna
09-14-2015 10:06 AM
Eglifestyle
10
03-23-2008 12:08 PM
-Championship-
11-14-2006 10:38 AM
Nos4R2
01-26-2003 09:40 PM
Quick Reply: civic fan dead, no heater.
