99 civic wont start
99 civic wont start
i have a 99 civic with a single cam... it turns over but will not start and u all u can really smell is fuel its real strong inside of the car.. can anybody help me out?
Re: (Silver89crx)
sounds like somethin that happened to me...i changed the cap rotor and got some fuel injectoer cleaner and she would start right up.
Re: (Silver89crx)
well a fuel pump never stays on it primes it self for about 1 to 2 ins then cuts off and the car ran just fine after i change the ecu and go new sparks and oil change but 1 problem it is spiting out black exhaust
Re: 99 civic wont start (Silver89crx)
did you replace your coil?
i just had a similar problem, turned out to be my igniter. car would crank and crank but would not turn over for anything! only took me 6 days to figure out what the problem was. i had no spark or no signal to the fuel injectors, and i smelled gas like crazy too. i had also noticed the CEL (check engine light) would not turn off either when i turned the key to the on position. anything sound familar yet?
i in turn replaced my dizzy cap, rotor button, plug wires, plug's, coil, and the main relay. nothing helped me out...... as a last resort i spent $220 at the dealership on a new igniter and that's where my problem lied. car started up rought at first, had to stay on the gas a little and it finally smoothed out. good luck!
i have a 98 civic lx btw. sohc too
I didn't see where you're 100% sure you've got spark? Also, a simple tranny/block ground would keep it from starting as well. If you've got spark, then start with the crank angle sensor...
Re: (blk92_d16)
alright i got it started.. i bought a new dizzy, but it still hesitates like it used to just not as bad and is throwing a code 10 and 41 which is iat sensor and a oxygen sensor.. could that make my car hesitate?
jdmoscar703
09-28-2013 02:36 PM
gordonsnow1978
10
01-06-2007 08:36 PM
boostedpleasure
13
10-12-2006 09:10 AM
