Heater blowing cold air?
Re: Heater blowing cold air? (scbmx87)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by scbmx87 »</TD></TR><TR><TD CLASS="quote">Probably a bad heater core.</TD></TR></TABLE>
Yeah, probably not.
With the car at normal operating temperature feel your upper and lower radiator hoses, if they are luke warm at best, you've got yourself a bad thermostat.
Yeah, probably not.
Re: Heater blowing cold air? (preludedriva)
if the hoses are hot (you can't keep your hand on them) then try backflushing the heater core with a garden hose.
Re: Heater blowing cold air? (averyvm)
my car gets warm i mean i see the temperature go up but as i drive it will go up and down depending on if im sitting still or cruising or on the freeway
and yes i felt my radiator hoses they are warm at best
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by preludedriva »</TD></TR><TR><TD CLASS="quote">my car gets warm i mean i see the temperature go up but as i drive it will go up and down depending on if im sitting still or cruising or on the freeway
and yes i felt my radiator hoses they are warm at best</TD></TR></TABLE>
If you go down a hill for about a quarter mile with 5th gear holding your speed does your water temp drop?
Thats how i found out mine was open when i saw it drop to the bottom line. Dosent help when you have bad heat with no interior either
Re: Heater blowing cold air? (hmtcrxsir)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hmtcrxsir »</TD></TR><TR><TD CLASS="quote">its bad to not have heat when its 12 degrees outside </TD></TR></TABLE>
so true
so true
Re: Heater blowing cold air? (98exturd)
when im cruising it will go down but when im sitting still the temp goes back up
where is the core located?
Did at any point did you take your center console off and where the cd player is i had to take mine of and the plastic peice broke i had to pull on the cable to turn the switch over to hot . Just a suggestion if youve take then off recented and forgot to take the ac peice off.
Re: Heater blowing cold air? (Frost7177)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Frost7177 »</TD></TR><TR><TD CLASS="quote">Did at any point did you take your center console off and where the cd player is i had to take mine of and the plastic peice broke i had to pull on the cable to turn the switch over to hot . Just a suggestion if youve take then off recented and forgot to take the ac peice off.</TD></TR></TABLE>
i did a integra dash conversion
tell you the truth dono if my car has been blowing cold since then i did it during the summer time ....welll fall but i had no reason to use the heater til now
i will check my cable though
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tjg0409 »</TD></TR><TR><TD CLASS="quote">I have two heater cores for you car if you need one </TD></TR></TABLE>
il let you know
i dont even know where the core is even located lol
il let you know
under drivers side two pieces big black things (no homo)
remove glove box
6-7ish 10mm bolts
unplug connectors whatever its simple
remove glove box
6-7ish 10mm bolts
Unceasing Measure
Before you go hunting through your car for parts that may or may not be broken, make sure your coolant is full and doesn't have bubbles in it. The number one reason your heater would be blowing cold air is if there was a massive air bubble in the core or if there was no coolant. It's happened to cars I've worked on multiple times.
Check simple first.
Check simple first.
UPDATE
i bought a new thermastat
took off the housing to find out i didnt even have a thermastat at all!
replaced it of course
filled my car up with coolant
checked my heater fuse its not blown but the connector thingy in the middle looks green and not bronze?
car warms up faster but still blows cold air
anything else it could be?
I had something similar, check the thermo valve wire from the temp control switch to the valve under the hood on the passenger side. If it had come off on one end it could be stuck cold (not letting warm coolant to the heater core). You can manually open the valve for a quick fix until you reconnect the wire.
