1999 civic dx hatch with b18b1 swap NEED HELP.........
help i have the motor swaped in the car its all down to the dizzy wiring now. I have tried to use a 00 ex harness no luck it has a small dizzy plug. Now i have a 99-00 si harness with the right plug and will plug up but i have no spark!!! so i looked around and noticed that there are 2 big wires from dizzy the black/yellow and a blue but on the si harness plug its missing the blue wire what do i do??????? please help!!!! thanks in advance!
Modified by cshatley at 1:19 PM 11/28/2007
Re: 1999 civic dx hatch with b18b1 swap NEED HELP......... (cshatley)
You gave us the year of the car but not the year of the engine. Saying that is like giving everyone the main street without giving a cross street. If you really want answers you got to get specific. Thats a Obd1 or Obd0 motor? With mounts its drop in swap. What your doing is like trying to fix the left wheel by starting with the right one. Swap distributers if you have to. Not wiring harnesses.
Re: 1999 civic dx hatch with b18b1 swap NEED HELP......... (RYNO48)
its a 95 b18b1 converted to obd2 have changed dizzys and harnesses no luck or matches
the black/yellow and the blue wires one is for the tach and the other is the coil. the wire has to be somewhere on that harness has it been cut off or anything. if not just run a new wire from the dizzy and find the ecu pin and run it like that.
Re: 1999 civic dx hatch with b18b1 swap NEED HELP......... (ltrkstr2k)
plug and harness hasnt been hacked at all and theres not a extra big blue wire anywhere. dose any one know the ecu pin for this big blue wire? i cant find a diagram......
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ltrkstr2k »</TD></TR><TR><TD CLASS="quote">the black/yellow and the blue wires one is for the tach and the other is the coil. the wire has to be somewhere on that harness has it been cut off or anything. if not just run a new wire from the dizzy and find the ecu pin and run it like that. </TD></TR></TABLE>
blue wire is the tach signal for the ecm, car will not run without that wire.
borrow a dizzy from someone with an OBD2 b series dizzy
Re: 1999 civic dx hatch with b18b1 swap NEED HELP......... (EFbomb)
to the top well boys and girls its alive just started it and purrs like a kitten
bseriesboosted
02-04-2004 09:56 AM
