Tightening Emergency Brake?
Re: Tightening Emergency Brake? (burgandybeast)
take off center consol arm rester thingy madooo and there is a cable with i think a 12mm nut tighten tht sucker down but not too tight. if its too tight the e brake will be engage when driving
Re: Tightening Emergency Brake? (koa)
Would I need to do this with the car on but not crunk up so i can see when the e-brake light comes on?
um i dont think tht will work because the the light turns on when the handle is pulled jsut tighten it to where it pulls 1/4 way up.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by burgandybeast »</TD></TR><TR><TD CLASS="quote">Would I need to do this with the car on but not crunk up so i can see when the e-brake light comes on?</TD></TR></TABLE>
What?? What is the problem you are having with your brake system?
Re: Tightening Emergency Brake? (EL Vap133)
I like doing power slides...besides my dad works at tire/mechanic shop get cheap brakes and super cheap used tires.
are ur brake shoes worn out? maybe u need to replace ur brake shoes and if still good, a longer way would be to adjust them from inside the drums, thats if u have drum brakes.....if ur e-brake came lose, when was last time u change brake shoes? before u adjust the cable for the e-brake u should check ur brake shoes make sure they not worn out- unless u know for sure they still good..
Re: (burgandybeast)
ok, then ignore what i said..and u should follow this previous post
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by koa »</TD></TR><TR><TD CLASS="quote">take off center consol arm rester thingy madooo and there is a cable with i think a 12mm nut tighten tht sucker down but not too tight. if its too tight the e brake will be engage when driving</TD></TR></TABLE>
Unceasing Measure
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by burgandybeast »</TD></TR><TR><TD CLASS="quote">previous post? i tried searching no luck </TD></TR></TABLE>
Just take off the center console and tighten the nut behind the bracket that holds the ends of both brake cables. It's not rocket science, noob. Go do it and then continue to drive like a jackass and get yourself killed
Re: Tightening Emergency Brake? (Archidictus)
k thx ill remember that besides its in abandoned parkinglots
and here in NC theres lots of those due to job loss...
BigZ88
02-21-2005 09:17 PM
JSPECHB
05-25-2004 04:25 PM
