Identify this dowell
Re: Identify this dowell (De_tour)
LMAO :ROFL: :ROFL:
not laughing at you, I'm the same way, just laughing at the situation!
sorry, I can't help, not without knowing where it came from (where the work was)
maybe it didn't come off of anything? I've lost stuff in my engine bay before, and found it later - when its a socket, and it says "Craftsman" on it, you know what it is, but in your case.....
:ROFL:
:ROFL:
well how does the car run if it runs good and isn't leaking or check engine lights maybe its just something that you picked up on the road with your tire or maybe it came off a lawn mower or something hahaha good luck buddy but its really hard to say what it is
If the head gasket has ever been replaced, it's most likely a dowel pin to align the head on the block. It probably fell off and has been sitting between the alternator and block for a while.
Re: Identify this dowell (spoon93)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spoon93 »</TD></TR><TR><TD CLASS="quote">thats from the trany when it connects to the block</TD></TR></TABLE>
Those are bigger in diamter.
Former Moderator
Re: Identify this dowell (LemonLime)
Call me crazy but couldn't it be a dowel from the alternator itself? I'm almost positive that there is a dowel pressed into the alternator where the lower pinot bolt goes through.
I mean it's not a big deal that it could be missing, but that's my guess.
Too big to be the head oiling dowel (under cam cap 3) and seems a little too small to be a head/block mating dowel. And I don't know that alternators have dowels. For it's size, if I didn't know any better, I'd say it's a dowel for those long upper cam caps (whatever they're called) but those don't exactly just fall out.
Former Moderator
Re: Identify this dowell (tmp_236)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tmp_236 »</TD></TR><TR><TD CLASS="quote">The dowel your thinking of i believe is a lot larger than that one.</TD></TR></TABLE>
Yes it's not so much a dowel as it is like a sleeve that doesn't make a complete circle anyways.
I think the alternator work and that dowel falling out are probably coincidence. As others have said it's probably a dowel that was lingering in the engine bay for a while and for what ever reason finally fell out.
GolfIVTyBiggums
09-09-2005 07:01 PM
mikensu
14
12-16-2004 06:11 PM
accordfreak
06-11-2002 09:52 AM
