Grinding noise when turning sharp
Old 11-28-2007, 09:50 AM
TokyoStatus's Avatar
Default Grinding noise when turning sharp
When I turn the steering wheel while moving to say make a sharp U-turn I start hearing a bad grinding. Im pretty sure its not from my wheels rubbing. Sound like its coming somewhere from the steering components. Also when the car is parked and off when i turn the wheel a little bit it will make a popping noise. It has no power steering. Just curious to what could be causing this and how soon I need to get it checked out.
-thanks
Old 11-28-2007, 11:27 AM
slacks's Avatar
Default Re: Grinding noise when turning sharp (TokyoStatus)
I have a very similar occurrence with my civic as well. It started happening when my mechanic reinserted my axle into the transmission. Could be a bad axle maybe?
bump for both of us :/
Old 11-28-2007, 12:59 PM
ekhatchling's Avatar
Default Re: Grinding noise when turning sharp (slacks)
Jack up front of the car, turn your steering wheel to the direction that would make noise when you made the U-turn and spin the wheel manually. See if you can hear the sound then and try to locate where its come from.
Old 11-28-2007, 01:05 PM
Resident Gearhead
BryanM.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TokyoStatus &raquo;</TD></TR><TR><TD CLASS="quote">When I turn the steering wheel while moving to say make a sharp U-turn I start hearing a bad grinding. Im pretty sure its not from my wheels rubbing. Sound like its coming somewhere from the steering components. Also when the car is parked and off when i turn the wheel a little bit it will make a popping noise. It has no power steering. Just curious to what could be causing this and how soon I need to get it checked out.
-thanks</TD></TR></TABLE>
I betcha it's a bad CV joint.
Old 11-28-2007, 01:06 PM
egstockboosted's Avatar
Default Re: Grinding noise when turning sharp (ekhatchling)
when's the last time you replaced your cv joints??
If you replaced them after they got real bad and didnt replace the axle it could very well be the axle. If enough grease leaks out of the cv it screws up the axle pretty bad. eventually you could be hearing a popping noise everywhere you go.
I found out its a hell of alot easier to just get a pre built cv and axle set up and just throw that in. its a little more expensive but to me its worth it in the long run
I would definately check that first, if not then.. start tracing your steering components and look for any unusual cracks or bending everywere.
Good luck guys.. i hate dealing with axles
Old 11-28-2007, 01:16 PM
spintboy's Avatar
i got the same probelm in my hatch.
i have ps steering though. and it only make the grinding noise when im making a sharp left.
Old 11-28-2007, 05:06 PM
slacks's Avatar
Default Re: (spintboy)
think something like this will last a few months as a light DD? Waiting for the spring time to swap my b18b.
Old 11-28-2007, 05:10 PM
Jbur074's Avatar
Default Re: (slacks)
stock motor?? year and model please
my gsr swap does that really bad...
Old 11-28-2007, 05:11 PM
JDM_SOHC's Avatar
sounds like the continuem transfunctioners gone bad...
haha j/k... it actually sounds like u got some axle poppage... maybe the o-**** ring on the end of ur axle popped off or something... u leakin tranny fluid..??
Old 11-28-2007, 05:57 PM
Default Re: (JDM_SOHC)
Yes its a gsr block. I just bought the car so idk how long its been since they have been replaced. I think I saw some tranny fluid leaking when i changed the oil last time. Ill lift the front and do as you guys have recommended. Thanks for the help so far!
Foster12
Transmission & Drivetrain
01-21-2017 01:58 AM
project91crxsi
09-18-2009 08:00 PM
ekcivic9
12-21-2005 12:58 PM
pr0phet
10-21-2005 11:54 AM
pr0phet
10-17-2005 08:24 PM
Quick Reply: Grinding noise when turning sharp
