99 Civic Driver's side knuckle/hum assembly...
Old 01-08-2009, 06:51 AM
EX-T's Avatar
Default 99 Civic Driver's side knuckle/hum assembly...
I think I already know that answer to this question but, will a '97 EX manual transmission knuckle/hub assembly work on a '99?
Also, will I need an alignment after changing the whole knuckle/hub assembly out if I don't mess with the toe adjustment rod?
I need a new wheel bearing and lower ball joint on mine and I found a whole new knuckle/hub assembly with a good wheel bearing and lower ball joint for $65 and would like to scoop it up...
Old 01-08-2009, 06:52 AM
EX-T's Avatar
Default Re: 99 Civic Driver's side knuckle/hum assembly...
Also, the car that the knuckle/hub assembly is coming from is non-ABS and had 95k on it. My car is non-ABS as well...
Old 01-09-2009, 05:44 AM
EX-T's Avatar
C'mon, someone knows a little about hondas on this site...
Old 01-09-2009, 07:50 AM
Resident Gearhead
BryanM.'s Avatar
Yes it's the same.
Old 01-09-2009, 08:18 AM
EX-T's Avatar
I figured as much, that's why I went ahead and bought it before you replied...let this thread die!
Old 01-09-2009, 09:50 AM
EL Vap133's Avatar
It is the same, even if one was for ABS and the other non-ABS.
hondafdj444
06-20-2014 12:27 AM
Jacob Weiser
11-24-2012 10:29 AM
my99ekcoupe
09-03-2010 05:28 PM
teddy_dc2
05-19-2007 05:09 AM
Quick Reply: 99 Civic Driver's side knuckle/hum assembly...
