Help - removing rear window box
Old 01-07-2009, 08:30 PM
dopamean's Avatar
Icon3 Help - removing rear window box
k so i got a hatchback. rear window has a motor box for the rear wiper.
anyone know how to remove this box?
thanks in advance.
dopamean is offline
Old 01-07-2009, 08:58 PM
The_Honda_Guy's Avatar
Default Re: Help - removing rear window box
A lot of interior pieces are simply "grip and rip." I'm not sure if it's the same case for that piece, but a lot of the stuff snaps in. Sometimes there's screws hidden behind other pieces though.
The_Honda_Guy is offline
Old 01-07-2009, 10:53 PM
bikewithnoname's Avatar
why you removing it? even non wiper models have the box. unless you have gromets to fill the holes and some alternative clasp to latch into your hatch leave it alone. remove the motor from the inside which i belive is three 10mm bolts i belive, and a 27mm i belive on the outside after you remove the wiper. and get the bolt in gromet from another CX. i havent done it in a while but i know you cant latch your glass down without the wiper box.
bikewithnoname is offline
Old 01-08-2009, 08:10 AM
dopamean's Avatar
i just want to remove it cuz i stripped all the tint off my windows and the last bit of tint is pinned between that motor box and the window, so i cant get to the tint underneath the box until i remove it... once i rip that tint off and clean the glue off the glass, i'm putting the box back on, that's all.
thanks for your help guys.
dopamean is offline
Old 01-08-2009, 09:21 AM
instructor74's Avatar
there a 2 philips screws that hold the plastic cover in place remove them pry the case apart. remove the nuts that hold the frame to the glass. If you have a rear wiper remove the wiper arm assy and the lage retaining nut the unit should now come off the window
instructor74 is offline
Old 01-08-2009, 03:50 PM
dopamean's Avatar
thanks instructor. very helpful. jobs done.
dopamean is offline
Highny
02-22-2016 12:42 PM
F4TJ0N
03-09-2008 05:14 PM
Eibach95Civic
05-02-2007 05:00 PM
JDM_Frijoles
17
04-19-2007 11:28 AM
Quick Reply: Help - removing rear window box
  • Ask a Question
Question Title:
Description:
