How Do I Fix These CEL Codes?! DETAILS PLZ!!!
can someone give me detailed instructions on how to fix a CEL Code 22 (VTEC Pressure Valve, and a Code 7 TPS-Throttle Position Sensor. I need to know how to fix them, parts needed, ect. Thanks for the help!!
Re: How Do I Fix These CEL Codes?! DETAILS PLZ!!!
Usually when the tps code comes on the tps is bad. It is located on the throttle body. It looks like it is riveted on but they are actually screws. If you cut a slit in the heads of the "rivets" you use a flathead screwdriver to just screw them out. You adjust the new one with an ohm meter. It is tested at wide open throttle and no throttle. It needs to be at a certain resistance when at both locations. I cant remember what the numbers are though. Hope this helps a little. I dont usually screw with vtec so I dont know much about the other code.
diyeealooen
10-11-2010 05:34 AM
