98 Honda B swap need help!
I have a 98 civic with the d16y8 getting ready to swap it with b18A1, i need to know exactly what all i need in order to complete this swap. Also wondering if i will need to buy swap axles or if the axles out of a teggy will work and if the wiring harness in my honda now will hook up to the b18? Need all the input i can get.
Re: 98 Honda B swap need help!
you need to get any B series axles. i had a d15 in my civic and i swapped in a ls vtec and just used my stock harness.
your also gonna need mounts from an 99-00 si, if you want to keep AC the drivers side torque mount from a jdm del sol, you will probably want to look into a radiator with bigger ports or you will probably over heat....def go through hmotorsonline they will hook you up with everything you need and the motors are so clean, i just put a gsr into my civic from them and it is sick
93CivNewB18
12-05-2008 02:47 PM
