si or dx rear wiper blade question how to remove it help?
how do you remove the rear hatch wiper blade off with out bending or breaking the wiper off ? for a 92 hatch
Re: si or dx rear wiper blade question how to remove it help?
if you figure it out and get if off clean and want to sell it to me cheap cheap ill take it from ya, i might even be willing to come out and give you a hand taking it off if you want. i have always wanted one on my cx
You take the nut off the motor shaft and take complete blade/arm off.
They are made as one unit.
I ground off bottom side of rivet that goes through arm that holds wiper blade, and gently pushed it out and removed blade.
I took blade to parts store and matched it up to another of similar size.
Then, I put a small flat washer inside where pin goes back through for spacer to hold blade tight, and pushed the shaft back in and JB welded the pin back on outside of bottom of arm.
The blade I found was an ANCO and had a snap on clip on it and the flat washer shim kept it tight after the glue sat up, I just snapped in on arm and re-mounted arm on motor shaft.
I'll try to find the number for the blade and re-post.
FakeJDMEF8
09-26-2004 07:39 PM
