Del sol Rear bumper removal!!
Hey guys,
tried searching but came up empty handed... I am about to attempt a trailer hitch install on my 95 del sol and just want some quick info on removing the rear bumper.
thanks in advance guys!
Re: Del sol Rear bumper removal!!
1992-95 MODELS
See Figure 7
To Install:
Fig. 7: Rear bumper removal-1992-95 models
See Figure 7
- Remove the rear trunk/hatch cover panels. Disconnect the license plate light connector from the trunk/hatch area.
- Remove the bumper retaining bolts from the fender well area.
- Remove the screws and then remove the under protector from the floor area.
- Remove the two lower mounting bolts from the trunk/hatch floor area.
- Remove the two upper retaining bolts from the rear of the trunk/hatch area.
- Remove the bumper by sliding it to the rear. Make sure that the bumper slides off of the bumper slide clips.
To Install:
- Install the bumper into position by sliding it into position.
- Install the retaining bolts and tighten to 16 ft. lbs. (22 Nm).
- Connect the license plate light assembly.
FoRmerLyMentAL
03-10-2003 05:49 PM
