Quick question regarding an ITR intake manifold.
I've got a B16A3 from a Del Sol VTEC. I've also got type-r cams tuned on hondata right now. I also have the JDM ITR 4.785 final drive set. My question is, would the ITR manifold be a worthwhile upgrade? I was reading through some of the archived threads and it seemed like the argument was that you'd loose out on some low end with the ITR manifold, low end that the B16 already lacks. But, with having the shorter gears (final drive set) I believe I've made up for that bottom end, so in my situation do you guys think it'd be worth it?
EDIT: The car is headed for boost next, just something to add into the equation.
Modified by sk8shorty012 at 6:03 PM 8/15/2008
Re: (sk8shorty012)
okay dude....final drive is almost the same okay....now the itr magnifole is like the b16 but yes i would use the itr magnifold.....won't give u much but **** it works man.....
Re: (tonylor89)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tonylor89 »</TD></TR><TR><TD CLASS="quote">okay dude....final drive is almost the same okay....now the itr magnifole is like the b16 but yes i would use the itr magnifold.....won't give u much but **** it works man.....</TD></TR></TABLE>
the final drive isn't the same? At 40mph in 4th gear i'm at 3,200 rpms.
It revs MUCH quicker and gets to the top end very quick, which is why I THINK the ITR manifold will help, but just wanted other opinions.
dutchman5
Texas -OK -LA (Sales)
10-29-2010 12:50 PM
