Power Steering - Which One Is The Return Line?
I am going to flush out the ps fluid on a 1996 EX. Manual states to drain the reservoir and then disconnect the RETURN line and feed hose into a container then turn lock to lock to force all old fluid out and then do a refill. Which hose is the return line to the reservoir? There is one on the side of the reservoir and one on the bottom?
Thanks.
Thanks.
Re: Power Steering - Which One Is The Return Line? (smeltjr)
IIRC, I'm pretty sure that they both serve the same purpose. For example, when you turn the wheel right, one line becomes a return line. when you turn the wheel left, that same line turns into a feed line.
ayoung101
10-03-2014 08:14 PM
