Removing or Replacing radio power antenna
New User
Well some **** snapped mine off while I was stopped at a traffic light. Luckily I had a replacement and decided I'd get on with it in the evening after work. BTW yes I do use the radio during rush hour for traffic updates lol
Tools required
-10 mm Socket with wrench
-Mole Grips (Pliers)
-Rubber Mallet
-13 Spanner
-A soft material which you can use to prevent scratching to your paint (Needs to be somewhat thin as you'll need to work around it, a sponge would be ideal)
-Your hands/eyes/a brain if you can find one laying around
ESTIMATED TIME TAKEN: 15 Minutes
1) Cover your paint/body with a protective piece of material.
2) Mount the tip of your spanner into the grove of the antenna fixture.
The flat inside part of your spanner must be level with the walls of the grove.
3) Smack the spanner horizontally with your mallet to the bottom of your spanner as seen in the picture below. It will take a few hard knocks to loosen the fixture. NOTE: You only want to loosen it.
4) Once this is achieved, take your mole grips and grip the edges of the fixture. Remember to only grip the metal bit not the black plastic, or the black plastic will look chewed up.
5)Keep rotating the fixture counter-clockwise using the mole grips until the fixture is loose and raised enough for you to pull.
6) Pull the fixture.
7) Pull off the black plastic housing.
8) Pop your bootlid/trunk
9) On the left/right peel back the carpeting.
10) Locate your Power Antenna unit.
11) Grab your 10 mm socket and wrench, loosening the small bolt holding the motor in place. You only need to loosen it not remove it.
12) Remove the rubber pipe which is connected to the motor
13) Remove the harness clip.
14) Remove the Power Antenna by pulling the bottom of it first towards you and then the whole unit should have enough clearance to be removed completely away from it's fixing point.
16) You will now be able to see the antenna cable which transmits the radio waves to your stereo. Pull away the antenna cable from it's socket.
JOB DONE!
I decided to replace mine, so replacing the unit is just a straight forward reversal.
Hope this helps somebody, because I couldn't really find any illustrated versions of the DIY and it fustrated me.
Regards
Sanjesh
Tools required
-Rubber Mallet
-13 Spanner
JOB DONE!
Regards
Sanjesh
Re: Removing or Replacing radio power antenna (sdots)
too bad the US cars didn't get a power antenna. oh well i have mine blocked off and use my Sirius
though i do want one for my EG
New User
Re: Removing or Replacing radio power antenna (95delsolz6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sageuvagony »</TD></TR><TR><TD CLASS="quote">How the hell did someone break your antenna at a red light? I'd be furious! </TD></TR></TABLE>
Well it was dark. They were hooded up in black. I only noticed when I heard something inside of the car. Looked into my left wing mirror and BAM! there he was the bastard, time I got out of the car, he had already ripped it off and made some nasty scratches to the paint. Juvenile's...what can you do?
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95delsolz6 »</TD></TR><TR><TD CLASS="quote">Good write up. </TD></TR></TABLE>
Thanks man.
Thanks man.
Location: ....................................................................................................
the integra usdm models came with power antennas from what i know, what do you the us models didn't come with one?
Re: (blkegcoupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blkegcoupe »</TD></TR><TR><TD CLASS="quote">the integra usdm models came with power antennas from what i know </TD></TR></TABLE>
common knowledge that integras did. this is the the civic forum though. and i have yet to see a 92-00 civic with a power antenna.
to the OP that is obviosuly a 4dr right? what year though.
H-T White Ops
Re: (NastyHabitzCRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NastyHabitzCRX »</TD></TR><TR><TD CLASS="quote">
to the OP that is obviosuly a 4dr right? what year though.</TD></TR></TABLE>
I figured it was a del Sol. '92-'95 sedans have the antenna on the a pillar (I believe in all countries... could be wrong) and the '96-'00 sedans have them in the same place, besides the '99-'00 ones (excluding the GX) in the US and some overseas ones, which also have them in the rear quarter panel. '99-'00 sedans (besides the GX) have them in the rear window glass.
Seagull Management
Re: (NOFX)
'92 - '95 JDM SiR sedans had power antennas on the rear quarter panel, i don't know of any other civic that had this. Heres a link to a scan of the sales brochure, you can see it in some pictures. http://civic-eg.com/viewtopic.php?t=1402
Re: (NOFX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NOFX »</TD></TR><TR><TD CLASS="quote">
I figured it was a del Sol. </TD></TR></TABLE>
lol that del sol looks to have a big trunk! besides isn't the del sol antenna on the passenger side?
looks to me to be a 96-00 4dr by the big tail lights.
DJNauTicz
11-25-2006 11:19 AM
