mini me bogging issue
So I finally had gotten my mini me (y7/y8) up and running. For the most part it runs just fine but after a few moments of highway cruising the bogging begins and I'm constantly switching gears just to maintain a constant speed. To fix the problem I have to turn off the car and turn it back on. From there it seems fine until a few minutes later the same thing happens. Any ideas? Thanks!
Re: (yusojdm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yusojdm »</TD></TR><TR><TD CLASS="quote">yeah the filter is on the back right under the mani and above the axle. if i remember right.</TD></TR></TABLE>
It's on the firewall next to the battery. Got any cel's? What ecu are you running?
Re: (gizzerhatch)
Tuneup time, check the condition of your wires, and spark plugs, Run some fuel injector cleaner, and higher octane gas for awhile. If it continues to do it you might want to inspect your injectors, but if that seems to look ok, it sounds like a ecu issue.
zuruk
09-25-2008 09:11 AM
