A/C broke Help! 112 degrees here in Vegas!!!
Old 08-17-2008, 07:17 PM
fluke702's Avatar
Default A/C broke Help! 112 degrees here in Vegas!!!
So I have a 2000 civic with 50k miles on it and the A/C stopped blowing cold air. Low and behold I saw one morning laying on my driveway was my a/c clutch! It's only the part of the very left that fell off?
My number one question is, how can I fix this? Do i need to replace the whole clutch assembly w/coil, the whole a/c compressor? I've changed my own radiator in my integra before so is this something I can do myself?? Please somebody. Thanks for your help!!
Old 08-17-2008, 10:42 PM
riceburnerryan's Avatar
oooooh bump for you, i just got back from vegas it was hot... but i plan on moving there soon have a few friends down there
Old 08-18-2008, 04:02 PM
fluke702's Avatar
Default Re: (riceburnerryan)
Was a high of 104 degrees today. Almost passed out even with the windows open. I think it was better with my windows up.
Old 08-18-2008, 04:24 PM
bbandco_keevee's Avatar
good jesus that's hot. wish I knew how to fix it, but I took out my a/c about 2 years ago ... lol.
Old 08-18-2008, 04:48 PM
DavidT or VajT's Avatar
Default Re: (fluke702)
Alright guy I'll try to help you out since living w/o A/C sucks period.
Right behind the clutch (the part that fell off) is a very small washer you have to get ahold of. Once you have that, find the front nut that holds the clutch to the compressor pulley. That's all you need. Put the washer in first, then the clutch and last put the nut on top of the clutch and tighten it all down. The clutch should be installed and tighten to spec with a feeler gauge but usually if you tight it good enough with a small impact gun it's fine and will work fine.
That is assuming you found the clutch that fell off (and your compressor was working fine before that) and can find a used compressor to take parts off of. Otherwise you'll have to swap out the compressor for a whole new/used unit or buy a clutch set from the auto parts store. Good luck.
Dc2chublu
05-01-2016 12:45 PM
onelovee21
07-15-2012 02:40 PM
madriagax619
Southern California
02-13-2009 09:23 PM
alpha_1
05-16-2008 08:58 PM
MINT90EF
06-08-2005 07:21 PM
Quick Reply: A/C broke Help! 112 degrees here in Vegas!!!
