oil???!!!!!!!!!!!!!!!!!!!!!!!!!
well if its regular motor oil youre talking about then find out where the bolt for the oil is and remove that be prepared that oil will fall out and youll need a pan to collect it ( its best if you drive your car around the block to warm up the oil but not too hot cause you dotn want hot oil now do you ) then after the oil has been drained use your oil filter tool and remove the filter, its in the back of the motor if the previous filter is original from honda then its blue remove that and use some of the old oil and ring it around the new filter and screw that in hand tight thennn fill in new oil and run the car for about 5-10 minutes!
H-T White Ops
Re: oil???!!!!!!!!!!!!!!!!!!!!!!!!! (jimmy193)
We all start somewhere. Things which might seem obvious to us, weren't always so.
http://www.google.com/search?q...fox-a
The first link has a video.
I didn't review all of the DIYs, but the third one looks like it has plenty of details that you might otherwise overlook.
The fourth link has photos and explanations to go along with them.
