axle seal leak wtf? help
i have a 97 civic dx motor with ex tranny... i changed the axle seal 4 times... still leaking... do you guys think it might be the stance of my car that creates the stress on the axles to bend the seal a certain way...my car was dropped fender to the tire, but i raised it up...help asap
anyone else have this issues please share...
Seagull Management
Re: axle seal leak wtf? help (HellerDopeEK4)
I would more likely suspect some sort of burr or ridge of the splined end of the axle is ripping the seal, or your ripping the seal when you slide the axle in.
Re: axle seal leak wtf? help (94EG8)
my axle is from kragen auto parts... it's not oem from honda... can that be the case..
does anyone else have this f'd up problem?
Re: (1992Si)
no...dx motor w/ ex tranny... dx axle... ex axle seal...
anything wrong? what should i try... it wasn't leaking when my car was 2 finger gap from the fender.. it started leaking a little when i slammed it...each time it happened
Solbros Owns Me
Re: (1992Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1992Si »</TD></TR><TR><TD CLASS="quote">The seals are different on both sides of the tranny. You didn't install the wrong one did you ?</TD></TR></TABLE>
impossible. The difference is a couple cm's.
If your seal is too far in, or ****-eyed, it will leak.
A groove on the axle will cause a leak too.
Go with a quality aftermarket axle like EMPI if you want OE quality
i had the same problem. My axle was causing the leak. Take a look at your axle to make sure that nothing is twisted on it. The end where it goes into the tranny. If you launch at high rpm's it's going to twist and that cause my leak. hope it helps.
Re: axle seal leak wtf? help (jdmcivic1)
wow...its been almost a year with the leak i had...im getting an oem axle from HAP soon...ill be sure to update if the leak is finally fixed..anyone else have this problem
Resident Gearhead
I did both seals and new NAPA axles and the oil seal on my pass. side started to leak a few feeks later. It looked like the axle may have chewed off the lip on the oil seal.
I've done a few of these output shaft seals before and this is the first one that has had that happen.
so is it still leaking ??? do you think an oem axle will not leak compare to a garbage aftermarket axle...???
I had this issue on my old EF dx, what happened was when I was installing the axle, I like to put a bit of trannyfluid on the end to make it easier to pop into place, but I accidentally brushed teh end on teh ground and it got dirty, so after a time that dirt scratched the seal just enough that it dribbled a few drops if the car sat for about a week. I got new seals, and made sure it was clean, problem solved. the leaky seals were brand new and installed correctly BTW.
thanks ppl...appreciate the concern and help...i think the whole problem is the aftermarket axle that i have...im going to HAP to get an oem axle and see if this will solve the little problem completly
yeah. so my tech hommie found out the problem... i needed some silicon to help seal up the axle seal to the case, let it dry for an hour... than put the axle in...tada no leaks...but now i need a new knuckle because a stripped stud...*** pressing the hub.. knuckles are hella cheap
undertheradar
10
08-21-2006 07:17 AM
