Can't set ignition timing -1993 civic dx 3dr stock
I need more advancment of the ignition timing and the distributor is at it's limit. The only thing I have not replaced on the engine is the distributor and a wrong exhaust valve spring that came with my re-built machined head. My vacume reading is showing ignition timing late and it is pulsing. I think the pulsing shows that there is a week cylinder. And like I said I found one exhaust spring that seems to be week and the wrong one for the head. I have a new spring from honda and was wondering if I need to replace the distributor since this seems like a vacume and map sensor error. Like as in the map sensor readings are telling the ecu a mismatching engine load conditions and so I can't set timing becuase it is retarding it. Any ideas master techs?
Re: Can't set ignition timing -1993 civic dx 3dr stock
Hmm. I kept my 8 valve head "the head that came with car but is not factory installed" and noticed the camshafts have the same posistions especialy since they use the same distributor. I did swap heads for a 16 valve head witch is what it is supposed to have. Since I have a vacume pulsation I will fix that first and check back with my results. I drove it on the interstate going up hill and it feels like a one week cylinder but not two or more. Anymore replies would be great. thanks.
werteg
25
12-16-2010 04:59 AM
