93 civic hatch with LS swap. CAR WONT TURN OVER ISSUE
Old 12-20-2010, 12:28 PM
ahtublao's Avatar
Default 93 civic hatch with LS swap. CAR WONT TURN OVER ISSUE
been having this problem where the car would just randomly shut off while driving. then it came down to the point where it wouldn't turn over anymore. I've checked all of the below and still no turn over???
yes it has gas
no it doesn't overheat
no oil coolant mixture
battery looks good,
just replaced dizzy with a new one,
im getting spark on all cylinders,
checked the main relay and its good,
ignition coil is good,
but now today i took off the timing belt cover and checked the timing belt and its a little loose on one side....would that prevent it from turning over???
please let me know your inputs if this is pointing me in the right direction and thanks in advance.
Old 12-20-2010, 01:03 PM
Former User's Avatar
Default Re: 93 civic hatch with LS swap. CAR WONT TURN OVER ISSUE
Did you replace the igniter unit with a new one?
Old 12-20-2010, 11:50 PM
ricky00's Avatar
check fuel pressure
Old 12-22-2010, 05:10 AM
ahtublao's Avatar
fuel pressure is good. igniter is good.....til this day the car still wont turn over. it'll crank tho.....still clueless if the looseness on the timing has nothing to do with it..........
Old 12-22-2010, 05:21 AM
Is there bright white spark at all four plugs? How do you know the igniter unit is good?
JDxEJ1
05-12-2014 06:20 AM
00trdtaco
06-03-2008 11:30 PM
sleepyitr
05-01-2008 04:22 PM
dc2doi
01-06-2008 01:43 PM
G a b e
12-14-2002 09:29 PM
Quick Reply: 93 civic hatch with LS swap. CAR WONT TURN OVER ISSUE
