Will the EX speedometer mechanism work on an SI cluster?
Seagull Management
Re: Will the EX speedometer mechanism work on an SI cluster?
Yes, but it will look ridiculous. If you have to actually buy a cluster to rob the speedo from go for a DX cluster or just buy the speedometer head new from honda.
Why would it look ridiculous? I'm just going to swap the mechanism from the EX to the Si cluster, no one would be able to tell the difference. Speedometer head new from Honda is 100+ dollars.
Seagull Management
I assume at this point then that you're trying to keep the Si gauge face? If the numbers are spaced the same you should be ok, if the spacing is different then no.
They look the same as well, but I've only been able to remove the needle of the speedo without breaking it. I've tried to remove the other needles and they break. I'll be getting a DX cluster today and will only be using the speedo. If you'll like, I can sell u the rest for cheap.
I bought a DX cluster today and swapped out the speedometer, it worked like a charm. Calibrated the needle using my gps and it's right on the money. The gas/temp gauge won't work on the Si because they are bigger single gauges since it's the DX.
JSPECEX
03-23-2003 07:53 PM
djmatix
08-17-2002 12:38 PM
