Where do I find a 12 volt wire hot all the time or only hot when car is running?
I have a 1997 Honda Civic. I am looking for a 12 volt wire that is Hot all the time. (Has power even when the car is off.) Another wire that is Hot only when the car is running. (Has power when the car is on.) Thanks
Re: 12 volt wire
check the various extra wires and male connections on the fuse box or use the wires going to the ignition switch.
...assuming you are looking for one in the cabin that is...
Re: 12 volt wire
radio is not a constant when the key is off to use form an alarm so i would not recommend that. you would rather run a wire straight from the battery
Re: Where do I find a 12 volt wire hot all the time or only hot when car is running?
Thanks for the quick replay. Yeah RonJ is right I ended up doing exactly what he said but I tested each wire.
matchewspoo
05-02-2010 01:47 PM
DIRTYsouthBB6
04-24-2006 12:47 PM
