D16Y7 jumpy idle after IACV cleaning. HELP!
Hey guys, I really need some help here.
I cleaned the IACV on my D16Y7 and when I started it up after I put everything back together, the idle climbed all the way to 3000 RPMs dropped down to 2600 RPMs and then back up to 3000 again. It just continues to do this.
I think I know what the problem may be but I need input. When I took the throttle body off, I removed the TB gasket to wipe it because it had coolant on it. Anyways, as I was carefully wiping it, the gasket bent a little. I panicked, but it seemed to straighten back out fine. Do you think there is now a vacuum leak or something?
Thanks for the help.
Re: D16Y7 jumpy idle after IACV cleaning. HELP!
It's likely, I had a vacuum leak and my D acted the same exact way. I'd at least start with a new gasket since they're dirt cheap and it's a good idea to replace it if it's bent, even if it's not the source of the surge.
Does blocking the IACV port inside the throttle body eliminate the surging idle or have no effect on it?
Any CEL codes?
If you removed the IACV coolant hoses, did you bleed the cooling system?
Any CEL codes?
I did remove the coolant hoses but did not bleed the system. Is this something I should have done?
You can pull the CEL codes using a jumper wire. Click the CEL sticky at the top of this subforum.
Whenever you potentially introduce air into the cooling system, you need to bleed it.
Is it possible I ruined something when cleaning the IACV? I pulled it out, and just sprayed the crap out of it with brake clean then let it dry for 25 minutes?
Pull the CEL codes. Then reset the ECU to see which CEL codes repeat after running the engine. Post codes that repeat.
Also make sure the throttle cable has about 1/2" of slack. If the cable is too tight, it will hold the throttle plate open and thereby cause a high idle.
I was reading that you should replace the IACV gasket when cleaning..other than that, I'm stumped. When I block the IACV port, and work the throttle manually, it runs fine. It has to be the IACV? But wouldn't it set of a CEL, or could it be that gasket?
Bleeding may take 20-30 minutes:
1) Park the car on an inclined driveway with the front end higher than the rear.
2) Push the dash heater lever/**** to MAX heat.
3) Follow the directions in the diagram below
I'm going to bleed the system tonight. I'm just wondering if it's dangerous for my engine to run it that long when the idle is surging from 2600-3000 RPMs.
Prior to bleeding the cooling system as I suggested, check whether unplugging the IACV connector causes the idle speed to drop. Post the results as this should help to pinpoint the problem.
Based on your information, the high idle is caused by the IACV opening and allowing too much air to bypass to the intake manifold. This could have multiple possible causes, including trapped air in the cooling system that causes the ECT sensor to falsely read a cold temperature or more likely a stuck open IACV (mechanical problem).
Edit: finished bleeding the cooling system, and the idle still surges. Only this time it surges from operating temperature (~700) to ~2600 RPMs.
Now I don't even know if it is the IACV, because the idle drops when it is at operating temperature, but still surges back up? What the heck is the problem here?
I'm getting so frustrated that I'm on the verge of taking it to a shop.
1) Does unplugging the 2-wire ECT sensor under the distributor cause the idle to settle down?
2) Do the same test on the 3-wire TPS attached to the throttle body.
Do you have a stock D16Y7 engine? What year?
So just as a little update if anyone has a similar problem, I replaced the IACV and the problem was solved.
Pashpacino
Engine Management and Tuning
03-13-2018 06:23 PM
apbtwhiskey
04-05-2013 01:51 PM
