HELP 96 EK STARTS THEN SHUTS OFF
Car worked perfect the day before (rain weather). Came out today and car would crank but no start. I did not hear my fuel pump prime or make noise. I went through diagnostics such as jumping the ECU, which did not blink or anything. I checked my ground wires, fuses, main relay(tested as well).
After doing that I figured to reset the ECU by removing the 7.5A fuse in the engine bay. Let it sit for 10 minutes and it turns on perfect. I hear the fuel pump prime, and CEL light turns off and car turns on! BUT! after turning the car off, removing the key, and waiting 1-5 minutes. Ill renter the key, and the check engine light stays on , my fuel pump will lag to prime at times or not even prime at all. Im now confused.
So...
-Fuel pump primes only with ECU reset by removing 7.5A fuse
-Main relay seems to be fine, clicks every time
-Could it be my fuel pump getting tired? or my ECU
-BTW stock D16Y7
ANY INPUT WILL HELP SORRY FOR THE RANT ITS MY D.D.
So...
-BTW stock D16Y7
Bushybob94
06-05-2018 11:40 AM
