What intake manifold for a single cam?
So I'm doing some research on which Intake manifold gives you the best gains for single cams. I know the skunk2 is based off the itr but like what are the gains you get if I were to do intake header and exhaust at the same time?
The Grumpiest
Re: What intake manifold for a single cam?
You'd probably hurt performance more than help since an aftermarket IM isn't a standard bolt-on. The standard IHE doesn't really add much for power and then you'd have to get a matching TB and a tune on top of it. Not worth it. For the money you should just swap or boost.
OP: you can buy aftermarket, but the Y8 is probably the best bang-for-the-buck manifold for the D-series. found mine used for $70 shipped. midrange torque is noticeable compared to the Y7. all that to say, you didn't mention which motor you have...
Skunk2 makes a manifold for the D series engine.
http://www.skunk2.com/engine-2.php?code=INPROD
OP: I wouldn't bother with the basic bolt-on parts like others have stated. The money you would spend could be better used for boost. Learn from others mistakes, don't waste your money with IHE. You can boost the D series and made good power.
probably a whole 3-4 hp tops gained.. and yours neighbor's peace and quiet and any good relations you had with them will be totally sacrificed.
on a d series your probbaly going to loose HP and TQ. longer runners are better for upper rpm HP but they say you will loose it down low. i have a edelbrock performer X on my Z6 but it feels slower with all the bolt on's without turbo. with turbo it probably helps.
1 Post
LOL LOL LOL LOL LONGER RUNNERS = MORE TOP END? LOL LOL LOL LOL LOL let me guess you read that on here and the y8 has a bigger plenum BIGGER IS BETTER???? lol lol
stock ftw
every other manifold is a waste of money until you make big power =] like forced induction stuff...
stock ftw
