97 civic obd2a bogging Need help
97 civic obd2 sohc zc bogging alll a sudden usually between 2500 3000 rpm cold and when warmd up but weird thing is not all the time CELL that ive always been throwing is 23 which knock N 8 for TDC my crank angle senser nevr was hooked up and my car never boggd nor was ther a knock senser....
Checked plugs/ & spark plugs checkd dizzy and o2
Do yall think o2 plugs wire getting wet will cause care to bogg here and there?//
any input greatly appreciTed thnx
Re: 97 civic obd2a bogging Need help
I should have done the obd2 to obd1 conversion but didnt...the car ran good the way I was running it just dont understamd the bogz now
Make sure that you do not have platinum plugs, Honda's HATE plat. plugs. This has been a problem in my car in the past.
If this is the case and they are Platinum plugs, try to get stock, factory NGK Replacements, However, if you check and you have standard plugs I would check your cap and rotor. Also, when was the last time that you changed your Fuel filter? This can also cause this problem.
Another thing, when was the last time that your smogged your car (seeings as you are in California) because this can tell us a decent amount of what to look for. Depending on your readings we can see if you have a lean/rich condition, if you're running too hot/cold, etc.
Good luck, hope that I was able to help you.
Fuel filter has never been changed out since ive had the car (3years)
And I.believe they are platnumz....what are chances that plugs wud cause it to bogg within that rpm range randomly?
It's very likely platinum plugs can case problems. Go get some NGK copper plugs, they're like $1.30 each.
New finding is that at 4 and.5 k rpm goes into limp but then cancels and lets vtec crack sometimes it xodoesnt.even crack.vtec and just bogs like it is in limp mode
in all seriousness.. repost the question, car, motor, and ecu in plain english with some kind of punctuation so we can understand what you are asking.
not having a knock sensor is going to retard timing alot.. the crank sensor is not goign to allow the motor to rev over 3500rpms with a rev limiter
we can't help you because we donttalke lik thiz in quoted runnon sentenzes that noone cun reed and figur out wether you are shopping list add or speaking car or mandarin. no complete stranger is gonna take the time to decipher that **** to help you with a car that you haven't even wired up all the sensors so it can run properly. are you serious?
wire it properly, come back and don't quote a fragmented thought for a question. or don't. either way good luck.
bhut2180
08-29-2005 07:59 PM
hondaowner
04-06-2004 04:42 AM
