b16 02 sensor question
i swapped a jdm b16a into my eg coupoe and was wondering about the o2 sensor can i use the singlecam o2 sensor or not and if not what one will fit the o2 connector on the eg harness and work..and also do i need to run 2 o2's or just one not sure if there are 1 or 2 on the car any information wil be appreciated thnx...
Re: b16 02 sensor question
If you're running a obd1 ecu you need nothing more then what the car came with. Just 1 sensor, same sensor is fine.
Hope this helps.
Hope this helps.
