changing cv joint. 95 civic ex
Hi so my cv joint went bad. when I make a turn it knocks real bad. I have already the replacement for the cv joint. Im not gonna replace the whole assembly just the outer cv joint. is it too hard to do it myself? or do you have a post? please help
Re: changing cv joint. 95 civic ex
there is a how to change an axle thread.
if you can do that, you can change the joint. only difference is, once you have the axle out, put the axle in a vice and clamp on the shaft wheel side hanging down.. then get a good heavy hammer and forcefully, but gently bang the outer joint off the shaft. it's only on there with the same clip and splines set-up that hold the inner joint in the tranny. and make sure you put the new boot on while the joint is off.. it's easy to forget lol
Save yourself the trouble and just install a new one. I once did just the boot replacement and it was a pain in the ****, not worth doing it.
Oh look, I can change this
^ Agreed. Just had my axles replaced due to CV boot throwing grease. Did both sides. New inner and outer boots, new axles, new joints, ball joints inspected ... now those things are dealt with and I don't need to worry about them anymore. Feels good.
yeah, just replace the axle. It's not that much more and makes the job much easier. Also, chances are if one side is going bad, the other will soon follow so plan on replacing both
hcaulfield57
11
02-05-2017 09:19 PM
HELLAnorcal
15
12-15-2005 01:26 PM
gtowni3
12-24-2004 08:09 AM
