Speedometer gone rogue
I have a 95 civic coupe with a b16a swap and my speedo is malfunctioning,It works when and only when it wants to, appears to not care if is warmed up, just started, sometimes it works, sometimes it wont. Ill be going town the strret at 25, and it will jump up to 90 or so, than back down. Half the time it works as needed... other times it wont work at all, also when it stays at zero my odometer stops working. Im not that mechanical but my friends are any tips so i can tell them things to try
Resident Gearhead
Re: Spedometer gone rouge
I have had this happen a few times, as a matter of fact it's happening right now to my '92 hatch with a B16A.
Before you go riping the gauge cluster out of the dash, just unplug the Speed Sensor (the only sensor located on top/back of the transmission) and check the connector and senor terminals for corrosion. It's almost alway green in color.
Go from there.
Like i said, im not to mechanical at all, btu my check engine light comes on from time to time, its obd1, so autozone couldnt check it when i brought it there, how do i figure out the code
Click the CEL sticky at the top of this subforum (or in my signature) to learn how to recover OBD1 CEL codes.
Reset the ECU (see CEL sticky). The next time you are driving and the CEL turns on, pull over and leave the engine running while you jump the service connector. Do you get code 23 again or do you get code 17?
Re: Speedometer gone rouge
Haha, I mispelled rogue I justy meant it as in it wont do what its supposed to, it has a mind of its own
Rogue-An unprincipled, deceitful, and unreliable person; a scoundrel or rascal
Re: Speedometer gone rogue
had this happen in my friends teg. it was happening for about 2 weeks before he spun a bearing and put a b20 in. when we were hooking everything back up, we cleaned the connector on the speed sensor (dragon fire ftw) and he hasn't had a problem. that was 2 years ago
ya mine kinda does the same, but i get no check engine light or anything... mine almost never works, sometimes will if i smack the dash, also, gauge lights do the same :/
I just had this happen as well. I thought it was the speed sensor, but even after replacing it, it was still doing the same thing. Luckily my brother in law has another Si, we swapped clusters and the problem followed. So, I bought a cheap DX cluster and swapped only the speed mechanism from it. Problem solved.
jaypinn22
11
07-30-2012 10:21 AM
x4and3r1991
11-14-2011 01:57 PM
95xEJ1
03-23-2011 11:32 AM
Brian13060
10-12-2010 10:05 AM
