Will NGK blue plug wires from B18B1 fit on a D16Y7?
Yo all. I gotz a question. My girl has an 01' LS but is about to start driving the 97 EK Hatch she just picked up. Naturally I wanna do a tune-up on her hatch right quick and i wanna kno if I kan take the $70 NGK Blue spark plug wires off her B18B1 in her LS and use them for her Hatch's D16Y7??? The NGK Blues are less than 5,000 miles / 1 Year Old.
Re: NGK Blues. B series to D series.
So if they fit i kan use em?? lol Would it be viable to check the resistance on the wires in her single cam to the resist of her blues??
Seagull Management
Yes. D and B-series engines have essentially identical ignition systems. Everything electronic in the distributor is interchangeable with a D-series, wire resistance should be about the same. Btw, if the wires on the D-series are original honda/sumimoto wires they'll probably work better than the NGK wires anyway. (NGK wires are great wires, but even they aren't quite as good as 15 year old original honda wires)
I don't think they are interchangeable, but go ahead and check.
Just get some Accel wires off eBay. They're ricey looking, big fat wires, but they're pretty cheap.
The clips on each end are identical but the seal on the valve cover is a different size. So yes they work, but personally I wouldn't run them.
Meh.. Wutz gonna get in there honestly? lol its not gonna end up running totally open anyways maybeh its worth it??
one wire might be short.. my buddy using my stock b16 plugs on his dx and cylinder 4 plug (the one closest to the dist.) is short from the dist..
So is he running all 4 b16 wires??? Or is cylinder 4s wire just way too short? Im still gonna check myself but my girl took her Teggy to her fams house. Forgot its christmas eve lmao
he running on 3 b16 n 1 d15 plug lol nothing wrong with it though cylinder 4 was like 2 inch short u could plug it but it wouldve been tight with no freeplay
if you try to run it that way and you get a misfire then it's a waste because you'll end up doing more damage than it's worth. If money is that tight then try it.
Anyone know the resistance spec of plug wires for a D16Y7? Im just gonna check the resistance of the wires on her d16 now and see if theyre in spec.
For the record, B series plug wires dont fit D series motors its a real sketchy fit and it feels like the plug wire doesnt completely fit on the plug or over the plug hole properly.
roachownsu
12-29-2013 09:32 PM
