16a6 into a 95 auto dx will it work?
So i picked up a 95 civic dx coupe for cheap. It is a auto and the block knock's like crazy!I have a buddy with a full d16a6 swap can i bolt the motor in will it work with the auto tranny and what all would i need to do?
Technical Hero
Re: 16a6 into a 95 auto dx will it work?
Yeah the only real difference will be the fan switch wiring will be on the back of the block on the A6 and its on the thermostat housing of the B7. You'll just to wire it to the back of the block. You can use the A6 intake/exhaust manifolds just reuse the B7's injectors. Also you'll want to swap over the B7 throttle body so the MAP sensor can be plugged up. Also you'll need to swap over the mount bolted to the block near the timing belt over from the B7 to the A6. Us the B7's distributor as well. Other than that you should be good.
Sweet thank's hondapartshero i cant waite to get to work on it. Im just trying to get it to run and just make it look nice.Going to be my dd and lil play car. Also it is that really light purple color what is that paint's name? Also is it a rare color if it is i dont want to paint over it.
dont know if its rare, but do NOT paint it
love that colour
Derek Shead
03-06-2018 12:49 PM
jdm.coupe3234
19
05-12-2010 09:50 PM
