B18b swap in eg throttle cable questions
Do i need the throttle cable from the integra, or will my stock one work? I attached it to the throttle body but I'm not sure how it bolts up to the intake manifold, or if it'll bolt up at all.
Seagull Management
Re: B18b swap in eg throttle cable questions
you can either use the LS throttle cable and bracket (ideal) Just make sure that you get a manual cable if you're using a manual gas pedal (automatic and manual throttle cables are different at the pedal end) or you can use the D-series throttle cable and make a custom bracket.
I have the brackets from both my car and the ls. I can't for the life of me find an integra in the junk yard that isn't just seats a frame. Any advice on fashioning this custom bracket?
I found a piece of scrap metal and I cut and drilled it to fit, she finaly started for me tonight
