97 civic ex coupe window problems
friends gf has a 97 civic ex, her drivers window rolls up and come off track. instad of going straight up into the top of the door it shoots out the top and creates a gap. window is kinda loose too, could this be the regulator being worn or not greased well? maybe the window channel needs some greasing in the rubber? she loves this car its in perfect shape with 110k miles. no rust. alll stock. just this 1 problem hoping to fix
Re: 97 civic ex coupe window problems
have the same problem too on my 93si..has manual windows... when i roll it down it come off the track.. than i have to open up my panel to put it back in roll it up n goes out the door.. work fine before..just 1 day i went to work n open the window n it all **** up
First you can try lubing all the rubber tracks with a spray silicone and putting the window back into the tracks, But from your description of the window bumping out when it gets near the top im willing to bet the regulator is bent, Or the window channels in the door are bent, More likely the regulator is bent.
You can get and OEM one from majestic honda for 75 dollars. Take the door panel off her car and inspect whats going on in there, If you need help takin the door panel off lemme know.
vsikwit
09-24-2010 06:47 AM
