What cams can i use?
i got an stock ls, a b18b1 from a 1994 is the year of the engine, am planning going boost and i got almost everything for it, i want to know what cams can i use for my LS, and what the stock compression of this engine in psi, 175?
Re: What cams can i use?
because later on i want to put a cometic head gastek, and some arp head studs, and also some cams for grow the boost, how much psi does this type of engine run safely?
The Grumpiest
This is going to sting but I see you have no real plan and little in the way of a clue. A search would answer all your questions. Getting parts just because you THINK you need them is not very wise.
Boost IS NOT something you want spoonfed to you. Anyone that does is not your friend and is not helping you.
Do some more research.
In the Forced Induction forum is a long running thread of B-series boosted builds. You should check there first.
psi is irrelevant, cams are a waste of money. that motor needs top end breathing room, which the ls doesnt have. 280-300hp is safely had, but you should do some more research and figure out what exactly you are looking for.
