94 del sol hydralic clutch line? help
ok i have a 94 honda del sol si with a d16y8 swap, now the clutch line from the y8 trans does not line in with the hard line that runs along the fire wall so im guessing im going to need a hydrulic line either from a 92-95 civic or even better a 93-95 del sol since the 96-97 came with the d16y8 and is odb2 so what i need to know is am i right about what i need as far as what car i need it from and is that the right name for the part....AGAIN i have a 94 del sol si with a d16y8 swap and the line that runs off of the trans that connects to the fire wall hard line does not match up im not trying to repeat myself i just want to make sure you know what i have and dealing with the more info the better
Re: 94 del sol hydralic clutch line? help
i also gotts know if i buy the 92-95 clutch line if it will fit on my y8 trans like will in go in the trans or however it works i havent messed with clutch lines that much so i dont know much about them i just wanna know if the 92-95 line will work with my y8
Seagull Management
'92 - '95 Clutch line is what you need. IIRC you need the bracket from a '92 - '95 tranny too where bracket attached to the line bolts up.
what is iirc and i ordered i 94 honda del sol si clutch line what is what orignally was on the car of course but im starting to think off another problem will the clutch line be right for the y8 now im thinking yes
Seagull Management
If I Remember Correctly.
'93 - '97 or '92 - '95 Civic clutch line will work fine (so will '94 - '01 Integra) clutch line will work fine with a Y8 tranny, but like I said the bracket/stay that the clutch line bolts to keep it from vibrating and eventually breaking needs to come from a '92 - '95 Civic/'94 - '97 Del Sol.
DelSol4REAL
07-13-2005 10:15 AM
crx4life2002
01-05-2005 01:44 AM
93EH6
05-17-2003 06:08 AM
