Ap2 Cluster wiring help!!!!
Re: Ap2 Cluster wiring help!!!!
you will need to cross referance a lil bit ap2 pinouts here http://eastcoastefcivics.com/index.p...ic=1740.0;wap2 ek pinouts here https://honda-tech.com/forums/showth...cluster+wiring many write ups on this. you will need converters for the engine temp and vss.
^^^^^ yeah I've come across those threads a million times, but I'm driving myself crazy by looking at them!! I have n Ap2 cluster out of an 06 n I'm not sure but I've came across a few posts wit some saying the pinouts r different then other AP2s.
I've tried cross-referencing using xalents writeup but the pinouts don't match/correspond with all my pigtails!! For instance he says to...
"To turn off the ABS light on the AP2 S2000 Cluster. *Just ground the Blue/Red wire at location B20 on the 30 pin connector on the AP2 cluster."(copied exactly from the writeup)
... But my 20location on the 30pin connectors wire is PINK!!!
Wtf goin on???
I also have wires that aren't black which have the same color pattern!! Is that right?
Wtf goin on???
if ur talking about the pink wire from the ap2 cluster it seems to say that b19 is pink and should be connected to a 12v source. here check this link and see if this helps any. it gives u the complete pinout and wiring diagram for a 2004-present ap2 cluster i hope it helps. http://www.k20a.org/forum/showthread.php?t=57830 and for the ek cluster see if ur wiring matches the colors in this link https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/94-97-98-01-integra-cluster-into-92-95-96-00-civic-wiring-diagrams-1053318/ i hope it all works out for ya... goodluck
That's the easy one, if I had that cluster with all the info on the web regarding that cluster my ahit would have been in!!! What are u tryin to swap it into?
Bigcalidave has the best for the Ap1 cut n dry!!!! https://honda-tech.com/forums/showth...ht=Bigcalidave
Still gotta get the lights off, but ill get back into it once the speedohealer and ect module comes in! Im just glad i finally got it in. **** was driving me crazy. I started to sell it and just get a CTR cluster, but Once i get a chance and everything worked out ill do a full write-up for the AP2in a EK because its no clear ones out there trust me ive searched!!!!!
luchura
03-12-2009 05:13 AM
