Toe Adjustment Bolt Spinning - PICS!!!
Old 05-06-2011, 09:04 PM
JasinC19's Avatar
Default Toe Adjustment Bolt Spinning - PICS!!!
Hey guys, could I get some advice here?
The bolt in the picture circled in yellow is pretty much spinning freely.
It is the bolt that adjusts rear toe. From the compensator arm into the chassis.
Where are the threads that hold this bolt in? As you can see in the pic, there is a closed off metal compartment hiding everything.
Is there a nut welded inside the compartment that might have broken loose?
I am trying to figure out the best way to fix this. Do I need to cut a hole in the metal compartment? (Where the green square is)
Thanks!
Jason
Old 05-06-2011, 10:05 PM
Linked's Avatar
Default Re: Toe Adjustment Bolt Spinning - PICS!!!
yea you need to cut that green compartment open, and it'll be right there
i need to do this exact thing
Old 05-06-2011, 10:28 PM
JasinC19's Avatar
Hey thanks for the reply.
Now that I had more time to research the problem, I see a lot of people cutting holes in their interior floor to rethread some kind of nut back on "track".
If I need to do this, why not cut the compartment outside the car? Is that compartment with the green square important to the structural integrity of the rear suspension?
This seems like a really dumb design to me.
BrokenBone
01-08-2014 07:23 AM
Dann6968
11
07-15-2012 07:19 AM
thekidsnitty
Suspension & Brakes
07-02-2012 05:57 PM
Eg253
Suspension & Brakes
30
06-24-2006 05:10 AM
kyorishin
04-11-2006 11:02 PM
Quick Reply: Toe Adjustment Bolt Spinning - PICS!!!
