D15B7 OBD1 IDLE ISSUE D:
Re: HELP: D15B7 WEIRD "TICKING" NOISE
if anyone knows if the engine noise is normal...
i would like to fix that idle problem but it doesn't bounce up and down on rpm
probobly just noisy lifters. a lot of hondas sound like that...
Trying to help a friend and figure out if thats a regular noise or something is wrong with it..... it sounds like if its ticking... i would not know if its regular sound. thats a problem
another problem is when its warmed up it stays at 1500 rpm and sometimes goes back to 700rpm and while its on 700rpm and you step on the gas it goes back up to 1500 rpm and stays... idk
If someone could help it would be cool!
http://www.youtube.com/watch?v=ZVmSruiIYrA
D15B7's are just rattle-tappy engines I think. Prolly rocker assy or piston slap. I remember reading that the D engine's bore/stroke design pushes the pistons against the cylinder wall hard as it runs resulting in inevitable piston slap. B engines are designed better in that regard.
They tend to take a beating until the headgasket lets go.
dude i wouldnt stress it, just regular ol "honda-tap" almpost every d-series will do this over time... at least all of mine did lol and ive had quite a few including my b7/z6 mini me im running now... never been a problem
Mine are like that. Original @250K miles and replacement with 130K on it.HG will be what kills it, unless, you never overheat.
so its normal...
now i need to figure out the idle problem
illl try to post the idle issue i have as soon as i can..
thanx for the help!
----->[FIGURED OUT] Trying to figure out if the d15b7 is a regular noise or something is wrong with it..... it sounds like if its ticking... i would not know if its regular sound. thats a problem ( From everyone who replied " its normal" ) THANX!
thanx for the help!
