1993 Honda del Sol S engine cutting out
OK, so I am having a weird problem with my car. Most of the time it works 100% fine, but 1/10 of the time I start to drive my car I have a few problems, like if I turn or I drive over a dip the radio will cut out, and if I make a left turn the engine will completely cut out. So I have to coast out of the intersection and restart my car.
I don't think its just the left turn motion, so much as it is any wide turn or large car motion, its just I don't make very many wide right turns, if any.
I am not really sure what the problem is.
BTW i have a D15B7 if that makes any difference
Re: 1993 Honda del Sol S engine cutting out
Check your grounds and battery connections.
The engine/trans assy is for the most part mounted/connected on rubber mounts/hoses making the ground straps important (one from frame to trans one from frame to valve cover). Also check the wire(s) bolted to the thermostat housing.
Don't know about the radio.. check the battery connection..
it was the battery connection, the people who put the new ones on my car messed up on one of them, it was halfway clamped to the rubber instead of the wire. Thanks!
mikeycivics
11-15-2011 03:57 PM
hondapwr
06-29-2006 03:54 PM
explosive
10-11-2004 02:28 PM
