A/C wiring Diagrams and Pictures?
When I purchased my car (95 Civic b15 non vtec) the previous owner had the a/c wired up to a switch inside the cabin. He rigged the wiring so he could turn the compressor on and off from the switch he installed.
I am trying to restore the car's wiring back to normal. I removed the previous owner's rigged up switch and wiring, but now i am having a hard time figuring out how it all goes back together.
The previous owner cut off the plug that came from the compressor and plugs into the harness, since i dont have it i don't know what it looked like or where it plugs in to. I also have a few wires coming from the relays that the previous owner cut and now i dont know where they go either.
can you guys please help me find some wiring diagrams or pictures of the wiring for the a/c. i live in florida and i'm literally going through hell right now.
any help would be appreciated.
Re: A/C wiring Diagrams and Pictures?
Probably easier to get a used harness and replace the existing one. Cheapest yards on the planet: http://www.picknpull.com/default.aspx Or nationwide salvage listings: http://www.car-part.com/
I believe just the A/C sub-harness. It should run under the top rail of the radiator support to the harness. At least I think it does. Go out to pick-n-pull and look. Even if it's the whole engine harness it shouldn't cost more than $30 (I know, I've pulled a bunch).
PS: Clear your in-box.
my inbox is empty, all the junkyards out here get the harness stripped from and sold off with the engines. very hard to find one intact.
what about the plug for my compressor though? its a thick red wire with no plug, does anyone have a picture of it?
I am also looking for the a/c wiring diagrams. I tried the FAQs but it keeps telling me there are no matches for "diagrams", "wiring", "a/c". I am new to Honda all around. How do I get to the diagrams???
The Table of Contents should guide you to the Climate Control/Air Conditioning section.
Thanks alot RonJ, Very helpful stuff there! Although, I didn't see any wiring diagrams for my car. I'll keep searching the forums....
The AC system has a separate sub harness that plugs in right behind the passenger headlight. It will be one of the larger sized gray plugs, like the engine harness uses on the passenger side. The harness has the plug, about a half dozen wires and a couple relays wired in. It's simple, but it's definitely easier and cleaner looking to obtain the correct harness.
I just removed one from my car. I'd sell it for a fair price if someone was interested.
2to5coupe
11-11-2006 12:11 PM
