i need help with (shim sizes/specs) d16 transmision and valve angles...
1 Post
Doing a LSD install into my EX SOHC trans I don't own a honda manual and i couldnt find and info online on specific looking for help on understanding how to shim a transmission case with 70mm &/OR 80mm shims-. i know you need to get a feeler gauge and all that but unsure about what the clearances mean i was told (.004) was ideal but how do i translate to the right size shim i need? based upon how tight or loose the gap is. and last question does anybody know the stock honda valve angles will they be close to my new aftermarkets or not even? deciding on whether or not to get a valve job now or later...
These are my new (aftermarket) valve specs
EXHAUST
26 mm 5.46 mm 115.95 mm 1.9 mm 22° Flo Stock size Flat Head
INTAKE
30 mm 5.48 mm 118.60 mm 1.9 mm 20° Super Flo Stock size Flat Head
EXHAUST
INTAKE
1 Post
Re: i need help with (shim sizes/specs) d16 transmision and valve angles...
anybody help? i need some real tech- not about ......
jdm jdm b16 b16 vtec cracking rims lips fog lights eg6 ek9 ctr itr
Mr. Vapor
01-16-2003 10:11 AM
